To add to this new catagory, here’s a problem I posted with a brief run earlier this year:
In five places, over a 40 foot stretch of both straight and curve track using the Aristo 8’ stainless rail and Aristo’s slip-on tie strips, the rail has continued to moved inward. Translated: The inside tie “spikes” simply allow the rail to press inward on them enough to move the rail inward. The outcome is most noticeable with USA rolling stock as it literally reaches those points and the wheels climb out over the rails – obviously derailing.
I have had NO, that is zero, problems with the 13 year-old brass track 8’ rail using the LGB plastic ties. Perhaps the brass rail is the reason – or the LGB ties have stronger holding capacity.
REMEDY: To date, I am making thin strips of plastic 1/2" wide strips to fit across from one inside edge of the rail to the other pressing the rail outward to the outer “spikes”. “Toothpick” shims of plastic stuck between the “spikes” and the rail have not worked well.
Other remedies? Other matierial other than plastic – which obiously is not sun proof.
Thanks,
Wendell
