After years of looking I was finally able to buy an Aristo RDC3. It is like new but it is stuttering at slow speeds and I do not know why. I had the whole thing apart to refasten a couple of doors and a window that had popped off and the electronics looked good and all the plugs were tight. I checked the trucks and there is plenty of grease and they look hardly run.
I use a Revo base unit and at 30% it starts to move but it stutters all the way up to 70% and it smooths out at 75% and above but that is too fast.
What is going on here? Is this common with these? Is there a fix? This thing appears to be so new that maybe it needs to be broken in? Yes I did add the Euro diesel sound to it.
https://www.facebook.com/100000657514790/videos/pcb.6236942806356581/938633670885238
Any ideas as to what could be wrong?
's question…Did you “open” up/take off the bottom covers on the motor blocks and actually look at the GREASE or perhaps PUTTY (by now) on the gears or did you just look at the grease on the trucks?
