Michael Turner said:
Yes sorry I meant Weld not Glue. Thank you both very much.
As they look like clean breaks I had considered matching them up right, then lining them up with an undersized screw to get the alignment right and then welding them back on. Then when the weld really has gone off, glue (e.g. epoxy) a reinforcing ring (e.g. brass bushing) around the repair.
How would that compare with Daktah John’s solution? Has anyone actually done either?
Michael- I have never attempted this exact repair. However, I have used MEK to weld many other plastics (repairs, new builds, etc.) and, once welded together, have never seen them fail at the weld. I’m no expert and your mileage may vary. Jon’s idea sounds good, as well, but involves making new parts (not my best skill). In my opinion, I would try and use the original parts first and see what happens. Worst case scenario, you have to fix it again using another method. Best of luck to you.
-Kevin.
