Hello all! I am currently building a 10 wheeler using an Aristocraft Pacific drive for power, however as designed the motor hangs out the back in the firebox and transmits power via a small flex shaft. due to shorter design the motor won’t work there and needs to be moved. I thought of flipping tho motor on top and run a small chain drive leading from the rear of the block to the shaft on the motor. Has anyone ever tried this, or have any other possible ideas for moving it?
Thanks!
Aaron
Silver Creek & San Juan R.R.
Loyet Lumber Company
Jerry, what kind of sprockets and chain did you use?
