I have no need to wait on the Aristo ore cars…if they ever appear…
It seems that there are 8 LGB ore cars on the way to the IPP&W…all seem to be the PRR lettering…no problem…we just mask the data lettering we want to keep (The car is generally box car red, or red oxide) and spray over the rest with red primer…then put new reporting marks and a number on them.It matters little if the primer is a match for the car’s original colour…the real pikes do this all the time, so the cars will look quite good.
Most if not all railroads that hauled iron ore in small ore cars, did not interchange those cars with many, if any other railroads. So it would be very unlikely to see ore cars of other railroads together in a string, or in a unit train. Some railroads purchased ore cars from other pikes, and did quick renumbering and re-lettering jobs…quite often only applying a number, and reporting marks, while painting over the former road’s name, number, and reporting marks.
Seldom were ore cars seen as individual cars in a mixed freight train.
The LGB cars are a bit different from other cars, in that their brake hoses are mounted rather high, and that practice was most known on the DT&I…so removing those high hoses is an option.
Replacing the couplers with a body mounted Kadee 820/920/1906 makes the cars close couple, just like the prototype…a rather simple job, worth the effort if you care how the full train looks.
The arrival of the 8 additional cars will give us a fleet of 30 cars. This fleet will be divided into 2 strings of cars. One will be loads and the other empties.
Compared with a real iron ore carrying railroad; 15 cars is nothing, but for an average outdoor railroad, it is a nice looking train. We will be running the train from one end of the pike to the other, picking up 5 car “Kernels” at three mine locations. The returning train will drop off 5 car kernels of empties, at the locations.
We run two separate operations on alternating weekends. NG, and SG…we do not mix the types of equipment. So…we also have a 30 car fleet of the B’mann wooden ore cars also, for that operation.
