Aristo Mikado Wiring Diagram
Anyone done a diagram of the boards in the live steam Mikado?
I am wanting to put a rear tender light on a Vandy tender I am converting to use with the Mikado.
Thanks,
Andre’
Wires go to the bulb…the headlight should be mounted up on top of the tender and facing to the rear…hope that helps!
hehehehe Knew I could count on you Bart
Andre,
Found this on one of Ray’s emails, I seem to have lost the diagram:
Pin 22 Red wire +7.2 volts
Pin 20 Black wire Ground
Pin 14 White wire Whistle
Pin 12 Blue wire Sound
Ray posted this on the Aristo forum:
Pin 9 is Fwd and Pin 10 is Rev. They are low level signals and require
the same type of buffer/inverter as the Bell/Whistle/Sound signals.
Now how do I get a buffer/inverter?..
Andre`
Ask Ray!
Good luck on a wiring diagram Aristo can not even come uo with a parts diagram of the loco. Later RJD
