Aristo LS Mikado Sight Glass Help Needed
I purchased two Mikados they are both needing water sight glasses.
The Aristo forum had a post that the glass is 6mm. Tried this and found it too large. Been told someone measured it at 5mm (3/16). Can anyone confirm this? Also since Aristo doesn’t have them in stock I have located a source elsewhere that will cut them to length and finish the ends as needed. I need to provide him with the length of the glass. WOuld anyone be able to get me that measurement?
Also what is used for a seal on the glass? Is it an O-ring or a fiber washer type?
Thanks
Andre’
Holy Cow,
Two LS Mike’s whoooo hoooo!
NO Stinkin replacement parts !
That’s why I’m afraid to buy one. I break things !
Andre,
You bought Dan’s Mikes? I looked at one, but was a bit leaery, hope it works out for you!
Jerry
