We acquired a GP-40 that works well on track power but when switched over to battery it runs about 2’ and shuts down. It then resets itself after power turned off, how do I fix this or bypass what is causing the problem.
Most likely bad motors, whole first batch had bad motors… you should measure the current being drawn…
