Almost everything that I’ve read about using batteries in the Dash-9 suggest that a 18.6 or greater battery be used.
Now, the CVP Web Site states outright that a battery of no greater than 14.8 volts be used because, “Higher voltage causes much more interference to be generated by locomotive motors which can impair distant radio operation.” (emphasis mine)
Now, it is widely known that I am electrically challenged. One of my shipboard Commanding Officers was not certain that he was willing to trust me with a light switch. So… what gives?
I don’t plan to try to control my locomotive from more than 50 feet away, at the most. Probably, the distance will be more like <10 feet.
Questions:
Does the Dash-9 (and other Aristo large locomotives) really require the high voltage battery if it is not going to be run as a “Lionel?” On my RR, 35-45 SMPH approaches the limits of “safety” for this Branch Railroad.
Is the motor interference from a >14.8 volt battery enough to really FUBAR everything as CVP states?
Is a 14.8 Volt battery enough to operate the Aristo large locomotive?
What distance is CVP talking about when they talk about motor interference?
The study of medicine is so much easier… fewer variables. :lol:
