I repaired a friend’s track-powered Aristo-Craft FA-1 locomotive that hesitated and stalled when I tested it. The motor blocks were opened to find the brass track-power pick-up wires (parts AA and Z) were broken on both sides of the motor.
It appears that the brass wires were subjected to high current, expanded, touched the motor casing, melted and fused to the casing. The owner did mention that he and his brother had problems with locomotives stalling on their USA Trains #6 switches.
The track power pick-up wires are .015” brass rod. I purchased some .020” brass rods (K&S part number 8159) and bent some new ones. The loop around the bearings was bent around the 10mm brass tube I use to repair USA Trains split axle sleeves on their drive gears. The motors now run well.
This summer I am going to visit his and his brother’s layouts to see why a lot of their Aristo-Craft and USA Trains motive power has ended up in my train workshop to repair melted track-power wiring.
