I have an Aristo Craft center Cab switcher that’s less than a year old. It ran in a satisfactory manner for a short time around christmas. Since then it will intermittently act like the track and or wheels are dirty. They are not.I have sent the unit back to Aristo Craft and was curtly informed that they had test run the locomotive for 3 hours and nothings wrong.(I think they tested it in a static situation) I took the thing apart,tightened the grounds, re soldered a couple leads and replaced shrink tubing. It doesn’t stumble and falter at the same place or under the same conditions. I had been running it on an auto reverse set up in my office. Sometimes it runs fine. I think all it can be is a short in one or both motor blocks. Has anyone encountered a similar problem,and if so do you have a fix? Am I faced with replacing motor blocks on a new locomotive? I like Aristo Crafts’ products I just don’t like the way they handled this.
Thanks,
Bill Wright
