I have a mix of both right now and need to pick one and go with it. I originally was going to use battery power, which is why I have both but I’ve changed my mind. I’m going to use track power.
That being said, should I sell the aluminum or the brass track I have? It’d be a whole lot cheaper to go aluminum, but I just want to make sure everything will run right. I’ve only seen people using brass or ss, so I wasn’t sure.
My railroad will be in a raised bed, floating on ladder based sub roadbed. I have approximatley 120-150ft of track…i probably should measure it. Anyway, I will be starting construction in the next 2 weeks…weather permitting.
Thanks,
Matt
