i got back today from arestocraft under warrenteety my a-c b and m rs-3 it head to go in for 1 dead truck . and smoke unit not working . well it now runs good but get overload light with used 5400 power pack if smoke unit is installed so tested smoke unit by itself found it works great . so i firged engine was wired wrong . switched wires going to clips . but still got overloadlight . toke smoke unit out engine runs fine . then put on track my outher ac rs-3 to run togather. won.t work get overload light . each engine will run fine if only one on track . so now i try b and m rs-3 with my g gage leonel power pack engine runs great and smoke unit works so wires were crossed . then added my outher rs-3 both units ran togather and both smoke units worked fine . so i think the 5400 is screwed up . we put a brand new a-c consaadation on track at club last mouth and got overload light on 5400 head to use mikes bridgeworks to run it . smoke unit worked fine on it to . . i like pause with control . should i buy a new arestcraft power pack . or anyone got a good one for sale. bobgfla
Bob your power supply does not have enough amps for the RS-3 you will need at least a 5 amp supply to run 2 RS-3’s There is nothing wrong with the power supply
Mike
