Kenneth Matzick said:
Dan
Would it be possible to include a link for a source of the ‘drill and press’ rivets you mentioned? Also, can you recommend an appropriate size for 1:20.3?
Thanks,
Ken
Not sure you need to go abroad. Tichy O scale riverts are $3 for 200. Those are the ones in my photo above. Not sure what size we used!
THESE ARE .035 DIAMETER RIVET HEADS. THEY ARE MOLDED IN RUST COLORED STYRENE WITH .015 MOUNTING POSTS. 200 PCS
https://www.tichytraingroup.com/Shop/tabid/91/c/o_nbw-rivets/p/8020/Default.aspx
Incidentally, I’ve had some success printing rivet position dots on a piece of paper, taping it to the side of the model, and drilling where the dot says to drill. Any decent graphic program can do that - I used Powerpoint for the pic below.
