<< If Safari has a problem with certain websites, you probably do need to upgrade to have full access to new web ‘stuff.’ You are correct that Safari 4.1.3 is the last version of the Power PC based application. It is incorrect that Apple is not upgrading Safari: Version 5.1.2 is the current one. Assuming you are still running it on a Power PC, you will also need to upgrade to an Intel-based machine.>>
I’m on an Intel Mac. The information posted on the Apple tech support forums stated that you need OS X 10.5 or later to use the newer version of Safari.
<< Meanwhile, software doesn’t wear out like a car, but websites are modernized to take advantage of the latest available technologies. A web designer working on a new project in 2012 does not want to be limited to only using the tools that were available in 2003 when the original 10.4 version of Safari was produced.>>
Yeah, well I don’t know what new bells and whistles they so desperately seem to need, but I have noticed that it’s usually the websites with lots of ads that give me problems. So my guess is, I’m being forced to change everything that currently works on my computer just so some idiot advertiser can find new ways to annoy me.
<< How long has it been since you restarted both Safari and the computer? That is one of the basic fixes for bad performance.>>
I know. I do it as frequently as possible, and of course after each freeze/crash too.
<< What do you you use for web access? The spinning beach ball is caused by either slow network performance, or by the size and complexity of the site being loaded. You can’t do anything about the size of the web content, but you might be able to get faster network access.>>
I’m using dsl, but that’s not the issue. Most of the time when the browser goes down, it flat out crashes.
Thanks for your help. I just really hate being forced to “upgrade”, and then trying to get everything working properly again, hoping I don’t lose anything I really need, etc.
On top of all that I can’t even get any help from Apple’s web site anymore.
