It was only supposed to be pixels on paper. At least that’s what I planned on when I started the design of this engine. After all, I run modern standard gauge equipment, what use would I have for a 1900’s articulated 3ft narrow gauge unit on my pike?
I wrote the story, designed the engine. It took a couple months of editing here and there to get the story right. Then, after the story I had to actually design the thing. I knew I wanted a garratt-style articulation. I also decided that the 3ft version would have to have outside frames. The engine was designed to be easily convertible from 36" to 42" and hence to 56.5" gauges. The road, as originally imagined was a triple-gauge line. The artics would need to be used on both the 36" and 42" lines, while the company’s ultimate goal was conversion to 56.5" standard.
Also, part of the design required as much commonality between a 2-8-0 based freight design and the 4-6-0 based passenger version. I knew that getting a larger drivered outside frame chassis was absolutely impossible, so I decided that the 4-6-0+0-6-4 prototype:
http://freightsheds.largescalecentral.com/users/jgallaway81/_forumfiles/AG-1%204-6-0+0-6-4%20Passenger%20Garratt%20-%20AGE-4601%20-%20AVRDivn.png would remain the only one built.
Meanwhile, the 2-8-0+0-8-2:
freight hauler would number very close to one hundred units.
During the design phase, I ensured that the drive wheel diameters would allow the sharing of the main rod between the designs. In fact, as much as possible is shared between the two designs. Part of drawing the engines was to feature the designs in the “history” book of the Freedom Central Railroad. Once I had them drawn, I decided to test out paint schemes for the A.G.E. During that time, the discussion on the connie kitbashes/customizations was begun here at LSC. After seeing one photoshop suggestion, I decided to integrate some of those suggestions into the final paint scheme:
It was at this point that things took a turn for the worst. I fell in love with my creation and decided I wanted one as a large scale model. So began the hunt for parts.
(Story to be continued after I complete my coming helper shift.)
-J.D.
