Rumor has it that if you connect “batteries” to the “battery” terminals, and flip the switch, the SOB will take off at Warp Factor 2.
That is really a “throttle” connection, just like the plugs hanging out the end of an Aristo loco.
Rumor also has it that one K-27 is running right now on radio/battery.
Rumor also has it that one can simply install screw terminals into the pads provided along the edge, and leave the dummy Ames Super Socker plug out, but all you are doing is using the entire board holding the Ames Super Socket as a terminal point.
Simply removing the board and clipping the wires, from rumors I have heard, will allow a simple, neat installation of anything you want to put into it.
Rumor also has it the coal pile is not hinged as on the prototype, and that water diversion channels have been provided, but that a “gap” has been left behind the coal retaining doors, so said water will simply flood the floor.
I have been made aware that this is an easy fix.
There is space accidently provided for a proper on/off and volume control switch, or so I have been led to believe.
Rumor also is that it goes around LGB 1600 curves just fine.
Dontcha just love these rumors?
