Yep, I am. I found similar lights at the Dollar Store back in April. Mine have a 200mAh NiCad AAA battery that seems to power these suckers all night long without issue. (Thanks to my cat wanting to be fed at 5:00 in the morning, I get to see the railroad often in the wee hours of the morning.)
I’m using warm white Christmas light LEDs in my buildings, and in the building that’s being powered specifically by one of these at the moment, I’ve got three LEDs installed in the building. In that installation, I’ve got the panel and everything stuck to the top of an 18" long stick (trimmed tree branch) stuck into the ground in a nearby oregano patch. Wires soldered where the LED was connected run to the building.
I’m also using them as general and accent lighting on the railroad. For general (very low-level) illumination, I’ve mounted these to the fence posts along the back edge of the railroad.
To accent the buildings, I’m not a fan of the obtrusiveness of the whole landscape light assembly, so I’ve taken to hiding the lights in my trees and shrubs. I use rebar tie wire to attach the lights to the branches.
I found Krylon’s Camouflage green paint to be great for blending these lights into the surroundings. (I haven’t painted this one yet.) I bend the LED on these so they point out the side at around 45 degrees rather than directly down. That gets more light on the adjacent buildings as opposed to the ground beneath the plant. In some cases, the light is so well hidden that you don’t know where the light is coming from at night.
While playing with these, I stumbled on another cool solar-powered LED light. This one is a 3-LED spotlight. The neat thing with this (beyond being very bright) is that the solar collector is easily removable from the light.
The “full” light is on the right. It’s casting an overall “bright moonlight” on one of my towns. I removed the panel from another one, and it’s powering the lights in the buildings in that town. I think there are 6 LEDs total in that circuit between the two lit buildings. I got this one at Big Lots for $6. Their stock changes frequently, so it’s anyone’s guess as to whether you’ll find one in a store near you. I’ve seen similar lights (at three times the price) at Ace, Home Depot, etc. I haven’t checked Wally World.
