Hi Guys, I will try to answer a few questions
I developed the ProtoHandsTM for those that care about scale fidelity. I wanted a fine scale gladhand that looked prototypical connected or disconnected.
The ProtoHands hands are Nickel-silver for durability and appearance. They have all of the prototypical features that keep the hoses connected and in-line. When viewed from above, the hoses connect in a graceful S curve and do not droop at the connection point. Just like the real thing, the ProtoHands have stop pins that engage the ears on the end of the gladhand. This prevents the hoses from sagging. The ProtoHands are extremely tolerant of various hose lengths. Better with hoses installed too long than too short.
After painting & weathering the ProtoHands will wear nicely; silver metal will show through where the hands routinely clap together or rub.
We are governed by the laws of physics: opposites attract. There simply is no way to mount a magnet in a prototypical gladhand that allows the car to be turned 180 degrees within the consist.
Even if both faces of each magnet are available (which does not look like a gladhand), it still does not work unless one of the magnets can rotate 180 degrees around the axis of the hose when the car is turned 180. Also, a simple magnet to magnet connection usually results in an un-prototypical V shape connection of the hoses instead of a prototypical, gently curved U shape.
The basic mounting approach is to assign all the B ends to one polarity. For cars that have two brake wheels or just for variation, the cars can be discreetly marked. Once mounted, a car rotated 180° within a consist will not mate with the other gladhands.
The problem of turning an engine and coupling to the other end of a train can be solved with two hoses (with different polarity) on the end of the engine or tender. My D&RGW tenders already have two or three angle cocks from the factory.
-The 1:20.3 ProtoHands are being released first.
-The development of the 1/32 version is almost complete and there are substantial pre-orders.
-We will move forward with the 1/29 development if there is justification.
Geoff
