program the old Aristocraft 27 mHz Train Engineer? I’ve got one in a boxcar, but I can’t remember how to get the transmitter to talk to the receiver.
I’d go look on the Aristocraft site, but for the last few days, I can’t access it. Dunno why.
Still won’t let me access the site. Can’t even “Save As.”
u gots mail, madwolf!
Let’s face it.
Polk doesn’t like you.
I saved it for you as well, if you still need it.
To reprogram the 27 mhz 10 amp trackside receiver, do the following:
Be sure to have 16 volts or more to power the receiver.
Be sure receiver is 3 feet or more form any power supply.
Keep the transmitter arms lenght away at a minimum.
depress the receiver code set button
depress transmitter key (B) and hold until it flashes.
Then depress a transmitter key again ©and hold, code light changes flah rate and then shuts off when you release the key.
The A-E keys program acceleration rate and delay, try different combinations to see how you like them. A is fastest, e is slowest.
Thank you all. I have it working, again.
What was the problem Steve? Did the Aristo site think it was me instead of you?
ha ha ha!
Never can be too careful
Greg Elmassian said:
What was the problem Steve? Did the Aristo site think it was me instead of you?ha ha ha!
