Jon Radder said:
I have an Accucraft Short Caboose I would like to convert to battery lighting. I removed the power pick ups long ago, but would kind of like to be able to light the markers.
It looks like just 4 screws under the floor and watch out for ladders. Is that it or are their hidden dangers?
Jon,
Opening an Accucraft shorty caboose can be an adventure the first time. Remove the four screws in the floor. Then CAREFULLY lift the body (including the roof) just enough to pull the top ladder stems from the roof holes. This is where most people BREAK a ladder or the handrails! Carefully slide the body toward the FRONT of the caboose (that’s the end AWAY from the marker lamps). This is about 3/4" to 1". Now lift the body and roof up and away from the frame and trucks. Moving the body forward allow you to clear the tabs of the body away from the bench seats on the floor frame. Difficult to explain. Hope you can figure this out from this note. Good luck with the battery install. I have a very old post from the early 2000’s from MLS where a battery install and interior work was explained very well. If you need that, I can email it.
