We had the bathroom remodelled last summer. Went from two faucets in the tub to one large Kohler handle. Off, to full blast and all the way hot in one half turn or so.
The problem is, it’s just not hot enough. In the summer, when the ground’s hot, and the incoming cold water is probably above 70 degrees, it’s tolerable. Now that it’s finally winter here, and the input water is colder, it’s impossible to get a shower that’s better than moderately lukewarm.
The sinks all have similar valves, and make plenty of very hot water. There’s no valve down in the basement, just two pipes coming up through the floor, and there’s no visible adjustment on the fixture itself.
So, before I go taking things apart for exploratory surgery, anyone know how you turn one of these things up a bit?
Matthew (OV)
