So I believe you actually took a thin layer of paint off all the surface and evened it out… with a solvent that was pretty gentle so as not to remove all the paint.
Goo Gone is in my arsenal, as well as many others… I usually try them from mild to wild …
Funny, I have a web page with them on it: https://elmassian.com/index.php/large-scale-train-main-page/misc-train-stuff/tools-aamp-accessories
Here’s the text:
So the listing will go from mild to wild, mostly by how these attack plastic.
- plain old isopropyl alcohol - usually safe on most plastics, but can cloud some clear ones and hurt some soft ones
- goo gone - usually mild but can eat some plastics, try first in a safe spot
- tape head cleaner - (isopropyl alcohol and trichlorotriflouroethane) - almost always safe
- pure freon liquid - great degreaser, but kills the ozone layer and you can’t get it anymore
- liftoff - (#2 most common, but get the complete kit of 0, 1, 2, 3) - Great stuff, use the #2 all the time for lables. It was made to penetrate stickers, and then release the adhesive so stickers just “lift off”. Medium mild, will attack some plastics, test first. Be sure to get a can.
- rubber cleaner - usually safe on everything, good for cleaning rubber before gluing or putting armorall on
- kerosene - good all around mild solvent, what WD-40 is mostly made of. Does not evaporate completely, leaves oily residue.
- tar and bug remover - sometimes works wonders, medium solvent, watch on plastics
- Kroil - (early 50’s magic lube and cleaner) - mild solvent that works better than kerosene
- Metafin - much like Kroil
- paint thinner - medium solvent, can attack plastic
- CRC-32 - really a lube and corrosion inhibitor, but has some solvent. Can clean some stuff and lube. The solvent can attack some some plastics, no matter what Lewis says.
- WD40 - I have a can. It’s like spray kerosene. It usually leaves a sticky residue, requiring more WD-40. Not good as a lube.
- Boeshield t-9 (also corrosion protection, similar to but better than crc-32)
- silicon spray - (there is a solvent in it) - can clean some stuff, but attacks many plastics. If it does not attack your plastic, cleans and lubes.
- brake cleaner - very good degreaser - safe on some plastics
- carb cleaner - degreaser and cleaner, but can leave funny residue on some metals, eats most plastics. Has it’s uses. Hurts your skin.
- acetone - melts or dissolves almost all plastics. Good degreaser, but keep off your hands.
- lacquer thinner - about as strong as acetone, seems to eat an even larger variety of plastics. Strong fumes!
- M.E.K - dissolves almost everything made of plastic, makes a good plastic solvent welder.
