Several summers a few weeks ago, while I was in college, I worked as the S.L.J.P.O.* at a summer camp for teen agers. There was an old tractor (built in the 30’s that had a 6 volt battery and that had, at one time, a starter motor. I only know how to start the thing with the crank. Set the choke, set the throttle, advance the timing, make sure both mags were on, prime the cylinders a bit, make sure the transmission is in neutral, give it a few turns just to wake it up in the morning, then start it up. Run back around to the controls, take off the choke, reduce the throttle, let it idle a bit to warm up, then go about the days business.
Several years ago, I went back to the camp to visit, and there was that old tractor, in the barn, under a bunch of junk, looking forlorn. I asked why they didn’t use it any more, and was told that it didn’t have a starter motor, so they couldn’t start it. They were thinking about selling it for scrap. I asked if I could try to get it running, and was told to “Knock my self out.”
I took out the crank, and after putting a bit of oil into each cylinder, and serendipitously finding new spark plugs for it hidden in a drawer, a turned over the crank a few times to oil the cylinders. Then I set everything for a start, and it fired right up! Oh, yeah, I had to put some gas in it. It had been stored with a dry gas tank by someone who thought ahead. It was still being used last summer, and is still going strong.
S.L.J.P.O. Navy acronym that means Shotty Little Jobs Petty Officer
