I’ve been replacing the Sierra SoundTraxx gel betteries with supercaps. I’ve found that three 2.7 volt supercaps in series with values between 6 and 10 Farads work well.
Well…, until they run out of juice. Then the sound unit may “sputter” struggling for enough voltage to keep running. The “sputter” can vary from a couple times to many times drawn out in intervals, and while this doesn’t seem to do any harm, it’s annoying.
Then when power is returned to the engine, the cap needs a moment(s) to recharge before you realize sound, and this too can cause some sputtering.
Of course neither of these issues raise their heads so long as you repower the engine before the caps run out of juice. But I, and many others have found these inconveniences well worth the price of not dealing with the gel battery.
With 6 Farads in series (2 Farads total), I get about 75 seconds using one manfacturer’s caps. I came across some 6.8 Farad units from another maker and figured these should give about 85 seconds. But I’m only getting about 55 seconds (in a different installation). It could be the impedience of the speaker, volume of the unit, etc. or the caps themselves as I purposely selected units with a higher internal resistance.
Be that as it may…
In actuality, one only needs ~30-45 seconds to let the engine spool down and go into idle and have the crew “do their thing” and then we can let the system turn off. So, we just need to shut off the cap before it runs out of juice.
My multimeter shows that the sputtering will start when the voltage gets below ~4.5 volts at the cap. So if we use a 6 volt relay, that will typically operate down to about 4.5 volts and let the cap power the relay while running one leg of the cap though the relay armature to the board, the system will shut itself off at about 4.5 volts until it sees power from the wheels which puts ~7 volts to the board. Instead of now stating from 0 volts, the cap still has ~4.5 volts on it. (Recognzine that caps don’t charge in a linear fashion except between about 1/3 and 2/3 of capacity and it takes more time to get from 0 to 1/3 as opposed to 1/3 - 2/3. Think sine wave.) This is also probably easier on the sound system as it now doesn’t see a “short” each time it has to start charging the cap from nothingness, except maybe the first cycle of the day.
If we want to raise this voltage a bit, to avoid sputtering and have power left in the cap when the engine restarts, we add a resistor in series with the relay windings to reduce its sensitivity.
But the relay consumes power and will shorten the useful life of the supercap. So, we need to find really low current relays that will trip at about 4.5 volts. I’m thinking that these will be the ticket and put in an order. They are rated at 6 volts and only use ~13 millamps, or a bit over half that of an LED.
I’ll let people know how it goes after they arrive and their trial.
