Well the Boss, Mrs What were you Thinking, SWMBO, has given a green light on a plan, we have purchased 3 pallets of retaining wall blocks and today I did a test to see what the approximate layout will encompass. Here is the plan drawing, I have made some changes but do not have current plan. Changes are on the south, bottom the inner track has been moved to close to the edge/walk way, and the town streets have been turned 45 to where they are now. Bridges are in same spots , but tunnels have been moved back from them and are more to the east side of the layout, and the outer loop had 2 tunnels with a short open space between them pencil colored areas are ground level , access and for viewing
A somewhat blurry picture of the changes to the east side tunnel changes,
View from the south looking north and the side of the house,
this is from the northwest corner looking to the east, All the Grass will be removed and this will become a large hill, with 3 bridges, an 3 tunnels
The shot s looking west from the patio, testing height of finished wall, I am thinking 4 blocks high, about 16" is enought, 5 may cost too much as far as fill dirt and extra blocks with not a lot of difference
This shot is from the Pool area looking west. Most of this will be filled and the " feature" will be the mountain, with the tunnels and hopefully water to go under the bridges, Big plans, I have enough track to make the outer loop and some sidings
I have a BBQ joint for the layout already on hand, now I need a dump truck full of dirt to stop by. Actually first I need to decide how to change the sprinklers to watering for the plants that will live on the layout and what electrical or wiring I would need to run before blocks and dirt get set. I would love to have LED solar lighting for the buildings and any features, just need to figure out what will be best way to accomplish that.
