A while ago i made an Aristo Mikado and a Lionel Atlantic into a reasonable approximation of a PRR H-9. I liked it so much I finally got around to making a second one. I already had a second aristo drive, and after much looking managed to find a non-functioning, beat up Lionel Atlantic and a non-functioning, beat up aristo Pacific. I’m just testing it out, and haven’t lettered it yet. I’m making it a little different in the details, mostly paint.
So far I’m having trouble getting the new one to track right–something’s off in the pilot truck. Need to work on speed matching them a bit better. They couple reasonably closely, but it ought to be possible to get them to run exactly the same. The both have the same drive block and the same DCC decoder
This is a relatively easy bash–you cut the running boards off the aristo frame, shorten it, and then the lionel shell just drops right down onto aristo frame/cylinders
