I bought a used Annie and found it didn’t operate. After some investigation into other causes I pulled the bottom plate and found the black wire from the track power pickups had broken somewhere inside. The connector to the pickup strips for both the red and black are there and connected. The black wire was broken off about 4 inches from the pickup connector. Loco works fine when I apply power to the two screw terminals under the middle driver.
Applying power to the red pickup and the screw terminal with black wires and I get no operation. Question is…where did the black wire go?
Thanks
Andre’
