I just got a Accucraft AMS short caboose and was surprised to find that it didn’t come with any documentation at all (no IPB, no wiring schematic, etc.). So I’ve got a couple of questions about what I have.
First the lights/wiring. Since I don’t have track power, I removed the wheel wipers (a real drag anyway) and the brackets that hold them and the wires. When I removed the box from the frame I discovered some type of circuit card in the area under the copula seats. I assume the circuit card is to provide a constant voltage to what appear to be incandescent lamps in the car and the marker lights. If this is the case, can I remove the circuit card and connect the wire to a 9v battery?
Second the couplers. I want to replace the couplers with Kadee 900 series. Is the coupler pocket compatible with these or will it be necessary to replace the pocket with a Kadee gear box? The Kadee conversion list only references a “large” or “small” pocket. This being the only AMS car I have makes it a little difficult to make that distinction. If the pocket needs to be replaced how is this done? Any help?
