Amaco metalic finishes
Has anyone tried using either of these products? Amaco metalic finishes. One is a rub on wax the other is brush on liquid. The advertise it to be used on any surface and after it is dry can be buffed to a desired shine. Sounds like it has potential. Anyone tried it?
Devon, The Rub N Buff line has been around for 40 plus years. We first carried it in the store when it was advertised for dressing picture frames with a gold finish. Has been available at craft stores as a staple for years. I found that it worked great as a highlighter worked into the recesses on frames and around raised trim you want to enhance.
I never though it would work as a large surface application, though YMMV depending on your taste.
