started with a basic frame
pilots started
basic frame together
plow on the front is a separate piece
Basic cab
Battery boxes, the back 2 were the basic ones I’ve used previously, the front two are the newest design which includes a diamond plate design on the finished surface
First attempt at the nose, it’s a little narrow (by 3mm) will fix on the next print
first long hood section done, needs a few tweaks, some of the louvers didn’t print, and i’m thinking about making the dynamic break box removable to cut down on supports required to print that piece
second long hood section done, had the same issue with louvers
3rd section on the long hood, figured out the issue with louvers
will print the last hood section overnight tonight
because of the issue with the louvers I’ve decided to go ahead and put this one together and print a complete second engine, with a little more detailing, like the diamond plate on the walkways of the basic frame, pilots, and the raised long hood walkway. even thinking about an interior for this one
