10-06-2016
I have a Bachmann Gramps Tank Car that I have been running for about 10 years. I decided to weather it using Ultimate Clay Based Weathering Washes. All the washes were applied by airbrush although you can brush them on too. Once applied I let them dry for 30 minutes then I worked them with a #2 flat brush. You can also remove the wash with a dry or damp paper towel and/or q-tips.
First the surface needs a smooth finish prior to applying the washes. I airbrushed a couple of coats of acrylic gloss (Alclad II Lacquer Aqua Gloss Clear) and let it dry overnight.
Here is the glossed tank car, trucks and wheels, reference pictures and Ultimate products. I did not need to use any thinner.
I started with light dirt and allowed it to dry.
Using a #2 flat brush, I removed the wash.
Sprayed some mud, earth, dark dirt and rust colors and allowed them to dry. Then I brushed off what I didn’t want.
Added some streaks of sand color and let dry.
Working with the flat brush it came out looking like this.
Worked it some more with q-tips and attached the weathered trucks.
Rattle can sprayed with a matte UV clear. This also tones down the weathering a bit.
Pros: The clay based weathering products are non toxic, non flammable, water based and don’t smell. Also if you didn’t like the way it turned out you can just wash it in water and removed the weathering (before you seal it with the matte coat).
Cons: Cost. The set of 8 colors cost about $45 without shipping. I have used the light dirt as a base coat so if I weather the same way, I will maybe get 8-10 cars out of that bottle. I see the other colors lasting much longer.
Tommy![]()
Rio Gracie
