Can someone suggest a good glue for adhering wood to Aristocraft track? (The plastic ties, not the rails.)
I’d try silicone but that depends on what you are trying to do.
The track is set into a concrete path, and I want to add wood between the rails like a grade crossing.
Make your wood piece, stain and finish it…and then stick it down with the silicone. It should stay. The stuff is designed for outside use. I used some on Kadee magnets between the rails and played hell getting them back up.
Warren is aboslutely right.
Silicone roof and gutter sealant sold here in OZ is brilliant. Just make sure the two surfaces are clean and free from any grease at all. It takes a day or so to reach maximum strength.
