My 2-Cyl Shay came with a blank number plate which I removed and stored. I bought a nice Shay Loco Works #2 number pin at Cass, cut the pin off and epoxied it to an Ozark Miniatures number plate that I ground flat. While running at Doug’s in Ottawa, the smokebox got a little hotter than usual and melted the white metal casting causing the number to fall off.
I’m ready to try again and won’t bother with white metal. Doers anyone make a brass blank number plate?
I suppose I could always silver solder up something from a few pieces of brass stock and tap it for threads. I’m wondering if I might melt silver solder with smokebox heat as easy as the white metal.
