Have acrylic car kits now available. They are CNC cut from 7/32 acrylic. Scale is 1:20.3. They are all narrow gauge cars from drawings in “A Century plus Ten” D&RGW book. My seemingly endless supply of acrylic went fast creating these so supplies are rather limited. I have the following: D&RGW 40 foot Reefer - Basic shell available in scribed and unscribed. Kit contains bottom, 2 ends, 2 sides, two roof panels and under roof braces. Roof is inset into the body shell due to the thickness of the plastic. (first pic shows a prototype which illustrates why the roof was changed to be inset) This allows a proper thickness roof covering to extend over the body.
Cost - plain $28 scribed $40 D&RGW 30 foot car - Basic shell available in scribed and unscribed. Kit contains bottom, 2 ends, 2 sides, two roof panels and under roof braces. Roof is inset into the body shell due to the thickness of the plastic. This allows a proper thickness roof covering to extend over the body. Usable to create reefers, boxcars, work, commissary and other cars of the same length. Same car as above but shorter! Cost - plain $28 scribed $40 D&RGW Caboose - Basic shell available in scribed and unscribed. Kit contains bottom, 2 ends with separate CNC paneled doors, 2 sides, two roof panels, under roof braces, cupola sides,ends and roof. Window opening corners will need to be squared as they are cut with a rotary bit.
Cost - plain $40 scribed $52 Shipping is not included but will be at actual cost, flat rate if its cheaper. LSC chat regulars can pay by any means with immediate shipment upon receipt. Others should provide payment via USPS MO, PayPal or personal check (kits held until check clears). Contact me at [email protected] or: Andre` R. Schofield 73180 465th Ave Jackson, MN 56143 507 840 0675
