One of the things I told myself at the beginning of this project was to use up scraps and try not to make more scraps…
That scrap pile of battens from last year was just enough to complete the short board and batten wall on the trackside.
I’ve got 3 more higher walls to cover this way so I’ll have to cut more strips. But right now the saw is setup for the wider shiplap strips. And I’m slowly remembering how I cut the strips last year. One of the keys to cutting the strips was making sure I “melted” the cut into the wood push stick.
If you’ve ever cut styrene with a power tool, you’ll know that you get those melted chunks. When cutting strips on the mini saw, those same melted pieces grab onto the wood and give a tad more grab while running it through. When the piece is cut all the way, the strip remains “stuck” to the push block. Then pop it off and clean the burrs. I have a deburring tool that works great. Don’t ask me what it is because I have no idea. But my great uncle who did plastic forming gave it to me for deburring plastic.
Edit: called a plastic edge scrapper. $15-20 depends on retailer.
According to Amazon has 4 functions… huh…
