Interesting find HJ. Having done GIS and arieal photo interpretation work in a previous life…
The problem is, with any GIS, what data sets are put into them. A GIS is not a true map per se. It is a Geographical Informational System. Basically layers of data that can be moved in and out of the base maps.
So if you start with say, USGS topo maps and add to that arieal photo data, it is a good start. But then the database of specifics has to be built, in the case I worked on, locating and cataloging data on USTs (underground storage tanks).
And then, the UST data could be used for several things, EPA water pollution info, fire protection, insurance/property transfer/Phase I work, etc.
So…
If the structure data set is from 1967-75, it will remain that way until someone finds a need to update it for whatever (property tax, fire insurance, environmental imnpact, etc.) reasons. Or if the data is completely un-needed, then good luck in getting that dataset updated.
