I purchased this at the ECLSTS this March.
Here is my non biased, non professional review.
The loco itself is beautiful, nicely detailed, and a pretty heavy piece.
It is also a lot larger then the USAT 44 ton loco… as it should be considering it is 1:20 scale.
I like that these engines come through plain with no lettering, this way it gave me my first chance to try lettering it on my own… with some decals from Stan Cedarleaf.
I was finally able to give it it’s first real run on my outdoor layout this past weekend, I have mixed feelings on it’s overall performance.
The Pro’s:
Looks fantastic, and it’s huge… very easy too see and grab your attention.
The headlights take very little applied voltage to be on full brightness.
On level ground it has great pulling power…
Negotiates turns & switchtracks with ease (I do have 8’ diameter curves and R3 switches)
Slow speed operation is beautiful… on level ground.
The Con’s:
The engine has what I call a waddle, it moves back and forth (side to side) as it travels on the rails. This I find very frustrating with a product of this price point and build quality.
It also has a very annoying squeak/scratching sound that I can’t seem to cure at the moment. I have lubed every moving part and it still makes noise… I hate noise.
I think it is coming from the motor brushes pressing against the back of the wheels, I may need to put a bit of conductor grease on the wheels to see if this stops the noise… but it is loud and distracting when you just want to sit and enjoy watching the trains run.
My biggest complaint with this loco is how poorly it deals with even the slightest grade, it stalls right out, even with only (4) AML & Bachmann 1:20 cars trailing it. The counter problem, is when you apply more throttle so it makes the slight incline… it now goes way to fast when it hits a downward grade.
Really wish that this engine had some type of a automatic speed control, it would help this piece a lot.
I really do like this piece, even with the issues that I have stated. It most likely will end up operating on my reversing section which is very level and will eliminate the stalling/speeding issues. It will also be operating at very low speed which will make the waddle less noticeable.
But I have to say again, it does look great outside!
