Just curious if any of you have had any issues with your gas flow between the tender and engine being “limited”.
I pulled the nozzle and cleaned it, it seemed to improve some. The line is completely open in between with no blockages.
It seems to be that it may be the valve on the tank by process of elimination. Not sure if there is anything I can do at that point, though?
Any other suggestions?
Thanks
Matt
