Guys,
Just got my idler flats and open gon sets today.
Everything is the usual Accu quality until you put them to prototypical use.
The flats set higher than the gons, thus defeating the purpose unless you put something under your pipes or long loads.
The regular run of the mill Accu flats sit lower and would work better for idlers.
The only difference they have smoothed up the sides on the idlers by removing the stack pockets.
The gons have the brake staff and wheel moved to one side.
