Just bought an Accucraft live steam Climax. I put it on rollers for a test run and noticed steam/water seeps from both cylinders once it got hot. Not surprising as it’s had very little use since new.
Does anyone know what size the cylinder nuts are? SAE or metric? Thinking a gentle nip up should fix things.
I’ve got an ElCheapo metric nut driver set but the 3.0 mm wouldn’t fit, and the 3.5 mm was too big. More than happy to invest in a good set once I know what to get.
Cheers
Neil
