Mornin’, Gentlemen - tac here with somebody else’s problem.
It might easily be solved [but not by me]. The owner lives in PA, not far south of Harrisburg - here is his address - shawn.poling[at]ymail.com. If any of you easties live nearby I’d take is as a real favour if you could help him out.
He writes in Youtube as The 301trainman.
Basically, his problem is that his 3-c Shay runs out of steam after about 50 FEET. Pressure is till up there at around 25psi, but nothing happens. Last night I got him to disconnect the drive to each truck, and they both roll easily, but when he took the heads off the cylinders to check them it was still almost impossible to rotate the crankshaft, he says.
He seems to be doing everything else just fine, but he is an admitted noob, and is a’skeered of busting anything.
All the folks I’ve spoken to with 3-c Shays like mine seem to have little or no problems running - heck, you can even push mine along with a bit of down-pressure, and it gets moving with hardly anything on the clock at all. Most of my running seems to be done with around 30-35 psi hauling humungous trains of log cars.
Thanks, Guys, and more thanks for all the birthday wishes - I sure don’t feel like 36 today!
tac, ig & The Vibona Bridge Boys
