MAKE THAT …$850 shipped…NOT $950 A used engine, runs very well. Here it is running a few weeks ago. Has a Summerlands chuffer too…sounds great. This engine has R/C but you’ll need to provide the Spectrum TX
Here’s a shot after it was painted but before the cab was reattached…which is why it looks tilted. Hi-Temp BBQ paint…Rustoleum The Cape Ann logo/lettering is vinyl letters
Electronics mounted in the back of the tender. A wall section was added to the bath so water can not get out via the rear
Servos are mounted between the frame for the Jbar and the throttle
A couple of shots of the cab area.
I control the headlight with a small lipo cell that fits under the front pilot beam…long range plans were to wire it back to the cab. The small screw/latch holding the firebox closed is busted…was on the to do list…that’s what the brass wire is doing now…holding it closed
Finally there are a few detail parts I did not put back on but do come with the engine.
