Richard Smith said:
Steve Featherkile said:
I suspect that “On the beam” comes from the early days of aviation, when a pilot would literally fly a radio beacon or “beam” to his next check point. Being “On the beam” was when the signal was the strongest.
Actually “on the beam” was when you heard a solid sound. Drift to one side and you heard a dot dash. The other side gave you a dash dot. This told you which side of the beam you were on. As you turned into the beam the two sounds came together to form a solid humming.
If the sound became louder you were heading towards the source while a gradual lessening meant you were moving away. These were called “Radio Range Beacons” and were prominent on all aeronautical charts along with their frequencies and call signals.
You also could determine position with omnirange signals. The only problem with these is that you’d have to correct for wind drift to avoid a spiral route to the source which used more fuel than a direct route. You straightened your route by crabbing into the wind.
Of course if all else failed there was the highly technical Seat of Your Pants method.
That’s what I was trying to say. Even earlier than the dots and dashes was following the signal from a radio station at your destination. That’s what the Japanese did at Pearl Harbor. So did the B-17s that were flying in that morning, according to my father’s cousin, who was the radioman on the lead ship.
