Okay I admit it, I am addicted to the Aristocraft AAR couplers. I know everyone has their preferences and I have tried many both in large and ‘N’ Scale over the years. But it is fairly easy to modify the USA Engines and Box/Rolling Stcok Cars to accept these couplers.
The tool you will need is diagnonal cutters. Once you have purchased the AAr knuckle couplers take your USA trains product, flip it over. Unscrew the knuckle coupler from USA. Once this is off you will have the coupler mounting shank.
Using the diagonal cutter snip off aboput 1/8 inch off the end of the shank. But you aren’t finished just yet. On the rolling stock are lips one on each side of the shank. You will need to gently trim these about 1/2 inch up the ahsnk. Once done, just drop your AAR knuckle coupler onto the USA shank and your rolling stock is good to go.
On the GP30 rngine, you will need to just scre down the couplers. They will work just fine.
Now you can use them with Aristo engines and rolling stock and they actually make a better coupler too.
