A typical alpine fountain for the critters
The first one is done, but not placed yet. Used the milling machine to hollow out the “log”, squared the corners with a HD knife (couldn’t find the scale chainsaw). Adjusting the flow of the water was a matter of scaling down the orifice of the spout, started at 1/8", down to 1/16" and 1/32" looks correct including the wave pattern in the trough. Too bad the viscosity can’t be scaled down.
Looks like your making the Baldwin sisters recipe according too pappa in 1:24
That could follow since distilling Schnaps has a lot of tradition with the mountain people, even in Switzerland. :lol:
add some dish soap. that’ll liven things up and break down the surface tension of the water
David Hill said:
add some dish soap. that'll liven things up and break down the surface tension of the water
The fountain is fed from the upper pond by the chapel, which gets the water from the "lake" in other words it's a very large semi-closed loop. Dish soap would certainly liven things up. :/ :O :/
I still think your makin booze with that HJ…:wink:
