**Steve “**My 1958 MGA is a classic example of this principle. Whoever designed this beast was convinced that he would never have to wrench on it.”
I have owned three British motorcycles and found that to be true. Unfortunately a British motorcycle engine has to be rebuilt every 10,000 miles. Several socket sets including Whitworth and British Standard are needed to work on them, as are a collection of special shop tools only available from Stockists in Britain.
A lot of the bolts and nuts are hidden in places almost impossible to reach. If you are going to work on a British machine, it is inevitable your fingers are going to get greasy and knuckles skinned. Nobody escapes unscathed.
The BSA primary chain case is fastened with a dozen screws of varying lengths. Why they had to be of varying lengths I never understood. There was one screw hole that needed a specific screw. If a longer screw was fastened in it, it would take it but block oil flow.
One of the bolts and a rear engine mounting plate had to inserted before assembling the two vertical motor block halves. A difficult task itself because the transmission, crankshaft, flywheel and con rods were heavy. I always chuckle when I see a restored BSA with that mounting bolt missing.
However my BSA Lightnings were two of my favourite motorcycles. The feel, torque and sound of them could never be copied by the Japanese. Normally I don’t keep something I don’t use. But I still have my 1967 BSA colour brochure and a book entitled “The Story of BSA Motorcycles” published in 1978.
