A new model
I am hoping that following this sentence there will be some pictures of a scratch built working railcar that I have been keeping myself amused with .
This shows the only kit part and is the cab from a Krupp truck .
With any luck , an overall viewhttp://
The above shows the working chain drive
General front end view http://www.lscdata.com/users/mike_m/Bus2.jpgThe working bits showing the very small motor --an HO motor is all that’s needed to push this along ,it is not a tug Finally the passenger bit . I left the roof removable to bung passengers in .
I suppose I should have said it’s about 1/22 scale on 45mm track
Not bad at all, Mike!
I see you can post pics to your thread.
We’ll work on getting them to your freight shed.
Very nice work, indeed! :slight_smile: :slight_smile: :slight_smile:
j
Not bad? its Outstanding!
Awesome job, I’m seriously jealous!
Mike,
Very nice. I think you and I share an enjoyment of these little creatures of the rail.
This has the scratch built truck you mentioned in the other forum?
Yes , brass strip/bar , bent up and drilled with springs in between to give equalising .The axle part is easy , the makng of the side frames is the longest job . Axle boxes brass cubes with a shapes filed on the face to represent stuffing box ,and drilled to take axles .
Mike
ps the truck for the 44 tonner is easier , you already have the motor block to hang everything from .I already did one for someone ,to full gauge ,outside rod drive used from original .
Very cool bus, Mike. I like it!
Mike, that’ s great looking railbus…
Great job Mike! Not only fine modeling but a great paint job too!
Wow, that sure looks nice! I keep thinking about building a bus - this will provide some inspiration.
What material did you use to make the body?
Bruce ,
I used the same technique as used to make flying model aircraft . The material is wood .
The ribs are spaced to represent the edges of the windows , and plated with very thin ply . .A sandwich is built up around the ribs using the ply , this makes one side at a time , and each side becomes very strong --the ply prevents "lozenging " of the ribs , and each side is then joined using a floor and ends made in a similar manner . I left the body as a bathtub assembly to allow for insertion of seats and also give access to allow for accurate positioning of the glazing .
The chassis is made like a conventional truck chassis , I used the existing differential as the drive point for the chain drive.
Bear in mind that this is a converted truck , a very heavy one at that , which gives ample power for a mountain railway bus . Trucks were commonly used for this .
Just put yourself in the position of the chap who got the truck chassis and the job of making it into a passenger carrier .
I have some photos of the construction , but as you know , have problems getting them to the site . I’ll see
what I can do about posting them .
Other little points not shown , but they are there , believe me , are access ramp ( kept in a stowage under the floor where the spare wheel was stowed ) springs , shock absorbers and so on . Also add things like tread plate by the engine access for routine oiling .You will note the oil drips on the body by this tread plate . The tread plate is made as I previously mentioned by rubbing aluminium foil over some tread plate that is available from military model sources ,thus indenting the pattern and giving a nice thin section to form round corners . The entrance to the passenger compartment is done this way too .
Mike
ps thank you all for your kind comments . There is more to this model than at first apparent , but I don’t want to bore you .
OK , Here’s a piccy of the framinghttp://
The reason for the pink marker colour is to give an indicator for sanding Get a highlighting pen and run it up each rib. .Then start sanding down and as each pink line starts to disappear , it will give an indication where the item needs sanding ,You use a rigid sanding tool held against a few frames at a time , thus getting them all to the same profile …ie . when the pink is still there , that part of the frame is lower than the stuff you have sanded ,Make sense ? You need them all the same or your sheeting cladding the frame will have bumps in it . The frames were cut from solid on my bandsaw --it is quite possible to do them with other tools ,knife , fret saw , you will see that the frames are glued to a stringer to keep them in place until the side cladding sheets go on . Please ask if you want more detail . Mike
Mike,
Andy C and I got together last night for dinner with friends. Your rail bus came up as a topic of conversation. All of us thought the work was fantastic. I had know idea the frame was built up from wood. Your paint job is fantastic and what a great color. Looks like a great means of transportation for the public or a track gang headed out to work on a unaccessable trestle up in the hills.
Thanks for sharing. Post all the pictures you can (practice makes it easier) and those that are not into this type of subject will just move on. I know many of us are interested in your techniques.
Very kind of you to comment at length , I shall have to post more . I didn’t realise it would spark so much
interest .
Funny to think this all started during WW2 when my Dad , bless him , gave me a penknife . I was 3 or 4 , and used to whittle sticks a lot , even carved my Grandad a walking stick with it .
I used to gather up the offcuts and give them to Mom to light the fire in the morning .
Then Dad got a wooden kit of a Lockheed Lightning from somewhere , very rare because they didn’t do the kits much , too busy in all the wood factories making De Haviland Mosquitos .
I’ve made literally hundreds of models in the 65 years since , from at home by the fire to out on jungle patrols ,never been without a penknife ,always whittling .
Which reminds me , must empty my bed . It’s getting a bit uncomfortable . ;<)
Mike M
My best wishes, Mike…GREAT MODELLING work…
Fr.Fred
Holy moly, that is one sweet model! I too, would not have guessed the body was made of wood. Excellent work Mike, and thanks for posting so much detail of the construction!
There’s more where that came from .
Mike Morgan said:
There's more where that came from .
Well then, show us, please.
See he has me begging! :wink:
madwolf
Steve ,
Sorry , I should not have said that , it doesn’t look right . Yes , I do have a lot of scratch stuff , and when I have got this blasted machine fixed , perhaps I can learn how to post pictures . I have only done piccies so far with a lot of help from some very nice chaps whose patience I do not wish to try . Patience is all .
Mike
ps thank you for your interest ,it makes a model more worthwhile when it gets a nod or two .
Some Lovely Craftsmanship there Mike----now that is Scratchbuilding to is best!
cale
