Variations on a theme:
the former loop, Eli and I took up all the track from the former loop, that long section is from the “trouble tunnel”…Note: Never build down hill tunnel!
painted outline, pretty simple, I bought a can of upside paint and traced the outline of the PVC I’d previously placed-(Pink because my daughter went to the store with me)
This is the digger I used to trench with. I removed two tines this time to dig a more narrow trench, it worked much better!
trenched-a reverse mole shot-took all of 30 min to trench all 3 loops.
didn’t use the rebar this time-went for the Garden Stakes and cut to 10" length. The bed this layout is built in is much “softer” than the last…and the Garden stakes were MUCH more cost effective, we’ll see. (I know they didn’t work for Kevin in CO)
PVC Down and attached to the stakes with zip ties.
another angle/different view of the outter loop. cale
When the ground fully thaws, the surface water will drain and the mud will dry up. Probably early April.
