A mad scheme is brewing for Durango & Silverton loco --> Here’s the notions rattling around the grey matter: 1. wood load from Glenbrook Valley loco 2. balloon stack from same Those are done.
Now: 3. instead of painting gloss black boiler jacket metallic black as dreamed up so far, use metallic grey like on PRR loco (dome bases will remain black) 4. shorten smokebox like did on V&T loco 5. paint smokebox PollyScale Steam Power Black like PRR loco 6. add rivet details to stack with http://www.archertransfers.com/catSurfaceDetails.html 7. chip off white tires like I did on PRR loco 8. ? maybe, shorten firebox about 1/2 to 3/4 inch ? 9. rearrange boiler jacket bands in front of cab and add one at end of jacketing at backhead. Strips of .015 styrene for that. Cut width to match model’s molded on ones, however wide they are - I didn’t measure, just held plastic sheet against existing and nicked end to match 10. molded on sand pipes have to go. will be replaced by wire Then won’t the rivet counters just love that baby.
